Can't Believe I didn't Think Of That!
Old Jul 21, 2010 | 01:14 PM
kenk's Avatar
Default Can't Believe I didn't Think Of That!
I have been chassing a shake in my frontend for some time now. Everything is new(almost:rebuilt swivel *****, all new bushings,wheel bearings, rod ends-all 4,alignment,rebalance tires,etc), so it was really starting to **** me off.
Then the other day I was putting new brake rotors on(needed anyways), and realize I had movement in the front tire at 12 and 6.
Thinking I just replaced the swivel bearings,bushings,etc, I thought how? No matter how much I tightened the wheel bearings, or how many shims from the upper swivel pin I removed, it was still there.
It's the stub axle. After much thinking about it, I tried an expirement. With the front wheel off the ground, I would get play. I had someone press on the brake hard,while still in the air, effectively holding the hub. Play was gone, rock solid. I got too much slop between the wheel bearings and the stub axle.
I thought them bearings went on and off a little too easy....
Old Jul 21, 2010 | 04:59 PM
At least you got it figured out.
Thanks for letting us know.
04duxlr
Oct 3, 2014 12:19 PM
wrongway1
Apr 14, 2014 07:09 AM
indasevens
Apr 13, 2014 09:09 AM
masism
May 31, 2010 08:47 PM
mowthat
Feb 14, 2007 10:03 PM
