Can't find o2 sensors
Old 04-25-2012, 09:07 AM
calebbo's Avatar
Originally Posted by Spike555
Hell, if you wanted you could even have your cats removed and nothing would change on your truck, however if you have inspections where you live it will not pass with the cats removed.
I have a '95 also, so if I remove my CATS (they are going soon anyways because they are rattling) will my Check Engine Light come on? No emissions here and I plan on going to school here for the next 4 years.
Old 04-25-2012, 07:56 PM
Nope, no check engine light for you.
And you can sell your cats to the local metal scrap yard, about $50 each.
Old 04-26-2012, 09:05 AM
Jmcavscout's Avatar
That is a tough one, the ecu should be good, double check that the connectors are plugged in all the way.
Roger I checked all the connections and plugs and they are in all the way. The window motors have power but only roll the window down and continues to attempt to roll them down even when there all the way down. When I press the up button it just stops the motor. Not sure if it is a short or relay and don't know where to check for those either.
Old 04-26-2012, 09:42 AM
calebbo's Avatar
Is there any performance gained from cutting my CATS? Or MPG gains?
Old 04-26-2012, 07:27 PM
Ok, now we are getting somewhere, I think your regulators as out of whack, remove the door panel and watch what is going on.
Maybe you can make adjustments?
loic
06-11-2007 03:52 PM
mburnett
05-28-2007 09:18 PM
dinandan
02-12-2007 04:25 PM
jmerrill
12-06-2006 11:59 AM
Evian
06-23-2006 01:59 PM
Quick Reply: Can't find o2 sensors
