Can't find o2 sensors
Old Apr 25, 2012 | 09:07 AM
calebbo's Avatar
Originally Posted by Spike555
Hell, if you wanted you could even have your cats removed and nothing would change on your truck, however if you have inspections where you live it will not pass with the cats removed.
I have a '95 also, so if I remove my CATS (they are going soon anyways because they are rattling) will my Check Engine Light come on? No emissions here and I plan on going to school here for the next 4 years.
Old Apr 25, 2012 | 07:56 PM
Nope, no check engine light for you.
And you can sell your cats to the local metal scrap yard, about $50 each.
Old Apr 26, 2012 | 09:05 AM
Jmcavscout's Avatar
That is a tough one, the ecu should be good, double check that the connectors are plugged in all the way.
Roger I checked all the connections and plugs and they are in all the way. The window motors have power but only roll the window down and continues to attempt to roll them down even when there all the way down. When I press the up button it just stops the motor. Not sure if it is a short or relay and don't know where to check for those either.
Old Apr 26, 2012 | 09:42 AM
calebbo's Avatar
Is there any performance gained from cutting my CATS? Or MPG gains?
Old Apr 26, 2012 | 07:27 PM
Ok, now we are getting somewhere, I think your regulators as out of whack, remove the door panel and watch what is going on.
Maybe you can make adjustments?
loic
Jun 11, 2007 03:52 PM
mburnett
May 28, 2007 09:18 PM
dinandan
Feb 12, 2007 04:25 PM
jmerrill
Dec 6, 2006 11:59 AM
Evian
Jun 23, 2006 01:59 PM
