Can't pop hood...just embarrassing.
Got a new (used) hood to replace my acid bathed hood, put it on and while working on getting it on straight I got it down with a little force and now can't get it popped.
The release cable is NOT broken, I can pull and no release though. Any tricks to get this thing up?
I tried pulling on the small wire leading out of the black box from underneath but no luck.
Here's a pix of what is covered up. The cable pulls that center wire wire going thru bolt in hole on the right, and that releases the latch in the larger hole. Pulls to right in pix to release. If you don't want to start on a Saudi Grille conversion, you can use a long thin stick and poke up thru a hole under each head light. You would snag the round spring latch that hold in the turn signal. Once it pops out, there is a bolt at the bottom that holds the trim under the head light. With those trim pieces out the grille will move a little, but still has several screws across the top flange under the hood you can't move. Since they are sheet metal screws, might be able to get at the bottom with long nose pliers.
It's like the small ball on the end of the post is stuck in there...the latch is released and I can't force the hood up. I'll figure it out, should have some time here at work today.
What I'm saying is that it is already "popped" but I can't get it up...and I know that sounds like a personal problem!
LOL, I only need to swap in a brake booster, replace the original coolant reservoir tank, and see if the new PS hose stopped the leak or needs topped off! Just normal weekly stuff here.
I finally got it. Had some help pulling the release while I yanked and wiggled...wait a second...I'm still talking about the hood I promise.
Anyways, apparently the spring was getting caught too as everything just wasn't lined up quite right, I will adjust everything tonight to get a nice straight hood line and release.
Case closed.
Case closed.
on
If it is bent or misaligned, that will cause troubles. Grease it good too.
I have heard of people rigging hand release cables just in case. We had to do something like that with my son's Honda, but his grill comes out easily.
Instead of a faux Saudi Grille, I have the American Redneck Version, it's two layers of expanded steel grid slightly offset with a small gap in between the two. Looks good, let's in more air, and won't dent if a large bug hits it like that gutter shield will.
