Cargo Door Hinge Replacement - How to?
Old May 10, 2013 | 08:12 PM
GramlingMan's Avatar
8th Gear
Default Cargo Door Hinge Replacement - How to?
OK, if the answer is already in here, I could not find it, so forgive any repetition in this my first ever post on this forum.
Cargo Door Hinge Replacement - There is a lot of discussion about broken hinge pins, alignment issues, etc. And some threads about obtaining a replacement hinge for a Discovery I. But no one has said how to actually DIY!
I am sure the inside door panel comes off first, but what steps do I need to be prepared for after that?
Thanks,
RON
Old May 10, 2013 | 08:32 PM
Heres the pages from the RAVE shop manual. From page 678 of 873 in the workshop manual if you have downloaded your own copy. Note that the door needs support assitance when you begin to remove it, any of the front four from Tiger offense should do...
RAVE stands for Rover Automated Viewing Environment, is a collection of factory shop manuals the dealer uses. We think it means Rovers Are Very Expensive. You can download the whole thing for free at links in my signature.
File Type: pdf
Old May 10, 2013 | 08:41 PM
8th Gear
Wow Buzz ... blazingly fast reply, thanks! And that makes it look simple so wish me luck. I also appreciated the suggestion to download the RAVE. I saw that in other posts and was not sure what it was
Thanks again!
RON
Old May 10, 2013 | 09:57 PM
XCELLER8's Avatar
fwiw....I replaced mine a couple of years ago AFTER the door fell off (almost) 300 miles from home.
remove the spare tire to lighten the load, have a buddy handy or at least a floor jack to help hold the door up ...remove the interior panel to gain access to the bolts....if you plan ahead you wont have to move the door very far so you wont need to remove any of the wiring....support the door and unbolt the hinges.... start all the bolts in the new hinges before tightening any of them....you can kinda see where the old ones were positioned ....snug the bolts a little and slowly attempt to shut / latch the door...when ya think its right , tighten the bolts....and put it all back together.
unless you park on a lot of hills, or have issues with a lot of wind in your area....get rid of the door "stay" on the bottom....if it hasnt failed yet, it will.
good luck !
srockrae
Dec 5, 2019 10:55 AM
PIROLOGISTS
Feb 21, 2012 09:33 PM
Camdisco24
Jul 9, 2011 10:49 PM
DiscoRom
Jan 22, 2009 10:06 AM
ajh
Aug 26, 2007 02:42 PM
