Center console insulation for R380
Old May 20, 2018 | 06:52 PM
mirrajumper's Avatar
Default Center console insulation for R380
Going after the interior clean up after removing stereo equipment, old wiring and decayed foam, carpet and insulation. I was able to install a new oem weather rubber on the tunnel and fitted a NOS center column and mat.
What I can’t find yet is the replacement black molded foam that goes underneath. Any leads??
I am on the hunt for a new window switch panel and cover also!!!!
Old May 20, 2018 | 10:50 PM
fishEH's Avatar
Get a squishy foam gardening kneel pad and make one.
Old May 21, 2018 | 12:33 AM
robertf's Avatar
I had mine out and a shore A durometer a few feet from it so I checked it. it doesn't even register on that scale. A gardening knee pad isn't going to insulate the same way.
Old May 21, 2018 | 07:51 AM
WaltNYC's Avatar
mirra....I have a extra wood switch panel cover (where the window switches go). PM if interested.
Old May 21, 2018 | 11:49 AM
fishEH's Avatar
That's why I said squishy.
Actually, the one I'm thinking of is marketed as a seat cushion. I have this one. https://www.menards.com/main/outdoor...4421318549.htm
It is very close to the original R380 foam. Perfect, no. But I can tell you it will be better than nothing!!
Old May 21, 2018 | 12:35 PM
DavC's Avatar
Try ultratouch denim insualtion, its like a soft batting insulation but the denim fibers are treated with boron fire retardant.
Couple videos online of people trying to burn test, it will smoke and just put itself out.
Easy to cut (tear really) squares or layers and stuff them into the tunnel spaces. Works good.
Old May 22, 2018 | 02:30 PM
Some great suggestions guys- will continue to sort it out and post up results.
Old May 23, 2018 | 09:53 PM
Hatchetjack's Avatar
Default The only actual difference is the shape of the cutout for the shifter right
Squareish for the manual and rectangular for the auto? Am I miss visualizing this bit? The differences are pretty small and the auto version would work?
Old May 24, 2018 | 10:53 AM
Underneath the console is a foam noise barrier, a rubber surround for the tunnel and sound insulation. It is these under layers that can’t be seen with the console in place that I am looking to replace.
i will post up some pics to clarify this week.
Jason Andrew
Nov 19, 2012 01:49 PM
DiscoIIBrandon
May 20, 2011 04:55 AM
Jay5oh
Mar 19, 2010 03:26 PM
jdelp
Apr 22, 2008 12:20 PM
chrisusvi
Sep 22, 2007 07:37 PM
