Central locking, probably a dumb question.
Old Mar 31, 2014 | 01:12 AM
slomatt's Avatar
Default Central locking, probably a dumb question.
I apologize in advance for the likely dumb question, but how is the central locks supposed to work on the D1? I have a 1996 SD with a 300tdi, so the wiring harness is swapped over and might be missing some features. The truck did not come with a remote for the locks, and I've always just assumed the SD models came with manual locks. But, while I had the door panels off for a project I noticed that there are actuators in all 5 doors, but there are no lock/unlock buttons like you would expect. Is there some Land Rover magic I'm unaware of?
- Matt
Old Mar 31, 2014 | 03:47 AM
From the RAVE shop manual electrical guide, page 249 of 546, the vehicles without Theft Alarm System (those are very lucky owners) are controlled by driver door lock. It has a small switch. Switch can be bad, door to frame cable can be bad, or just satellite fuse block 2 fuse number four (which is easier to get at than the door switch).
Old Mar 31, 2014 | 07:14 AM
TOM R's Avatar
Prev owner probly lost remote, and dealer gave crazy price so said f it
The alarm box is green box behind glove box on dash iirc
Old Mar 31, 2014 | 03:52 PM
slomatt's Avatar
Thank you for the replies. I'm going to be pulling the drivers side door off to adjust the latch (already did the passenger) and I'll check out the switch while I'm in there. The truck does not have the alarm system that I'm aware of. I will also check out the fuse.
- Matt
earlyrover
Aug 8, 2015 05:32 PM
bcbp
Jun 3, 2012 12:39 AM
armlock
Dec 29, 2007 07:20 PM
johanba
Apr 3, 2007 11:37 AM
gazthevan
Apr 14, 2006 01:28 PM
