central locking system not working
Old Aug 20, 2010 | 05:00 PM
ruggles's Avatar
Default central locking system not working
any ideas of why? Is there an ecu like the windows that doesn't work? I tried many searches on here but couldn't find anything.
Thanks thus is for the power door locks btw
On a side note I fixed my tranny! woo hoo
Old Aug 20, 2010 | 08:44 PM
You didnt search very hard.
This is the most common problem with DI's next to the ABS.
No there is no computer, it is gears and a lever, the lever is seized.
You need to crawl under the truck and lube the CDL linkage.
Work it from the inside and then lube it some more.
Eventually it should free up, once you get it working you need to exercise it ounce a month to keep it working, you dont need to off road, just in your driveway move it through all the positions.
As for the rear windows not working, 15 min fix.
The window lift ECU has a crack in the circuit board, remove the board, resolder it, put it back and the windows will work again.
The window lift ECU is behind the glove box.
Old Aug 21, 2010 | 09:27 AM
discomedic4's Avatar
Spike, I think what he was asking is that his electronic door locks are not working and he wanted to know if there is an ECU that controls that. If so is it a simple fix similar to the rear window solder fix. At least that's the way I interpreted the question.
Old Aug 21, 2010 | 09:35 AM
ruggles's Avatar
Thanks discomedic yes I was talking ablout the door locks. Sorry for not being more clear. Where is the ecu for that?
DiscoBlanco
Dec 19, 2012 01:55 PM
danvlarsen
Mar 17, 2011 12:00 PM
johanba
Apr 3, 2007 11:37 AM
william
Sep 25, 2006 05:22 PM
gazthevan
Apr 14, 2006 01:28 PM
