changing panhard bushings - how hard?
Old Dec 9, 2012 | 07:28 PM
  #21
jfall's Avatar
I put in rubber twice - and it failed twice.
Actually, A shop Mark's Automotive put in rubber twice and it failed twice.
They said oil leaks were rotting the rubber.
They also fixed the oil leaks.
I don't think it was totally the oil.
I think they were putting in junk Chinese parts. Not sure.
I put in Poly's from Lucky8.
Only in one day and steering is back.
Just a tad - very small wobble now in the new poly on the driver's side.
Seeing any wobble at all - is worrysome.
Here are some pictures of the job - in the parking lot.
The poly bushings just fit into the large bar by themselves without the need for the outer steel ring which the rubber was formed into.
You can get that ring out with a hacksaw.
Take the blade off of the hacksaw.
Put the blade thru the hole in the rod.
Put the blade back on the hacksaw.
Saw thru the metal retainer ring.
Get a small chisel and hammer and push it into the center by hammering it all the way around and it will just fall out.
Attached Thumbnails changing panhard bushings - how hard?-panahard3.jpg   changing panhard bushings - how hard?-panhard1.jpg   changing panhard bushings - how hard?-panhard2.jpg
johnnyjohnny
Sep 26, 2019 09:37 PM
MM3846
May 7, 2014 07:17 PM
MarkSF
Mar 17, 2014 12:38 AM
JPSpen
Oct 15, 2012 10:51 AM
dillhole
Aug 23, 2009 07:53 AM
