Changing rear brakes
Old Sep 13, 2012 | 07:26 AM
Tara Vorenkamp Scott's Avatar
Default Changing rear brakes
I have a 1995 Discovery and need to know how to change the rear brakes. Any suggestions.
Old Sep 13, 2012 | 07:56 PM
See if this page from the RAVE shop manual (all free at links below) helps guide you to pad-slap that primo possum smasher. I'd block the front wheels carefully.
File Type: pdf
Old Sep 13, 2012 | 08:07 PM
Buy the brake pads of your choice.
Buy a new brake hardware kit.
Remove the wheels.
Remove brake hardware.
Using a pry bar with old pads in place pry the calipers open.
Remove old brake pads.
Install new brake pads.
Install new brake hardware.
Put wheels back on.
Done.
No need to remove the calipers unless you are doing rotors too, then that is a whole other story.
FightOnUSC79
Nov 26, 2010 09:43 AM
amvauto
Sep 18, 2008 07:38 PM
hollis
Sep 5, 2008 12:53 PM
m1964
LR2
Jun 15, 2008 10:06 PM
flygirl92
Apr 29, 2008 03:48 PM
