Check your fuel regulator vacuum line!
Old Nov 6, 2015 | 09:25 AM
Tracker1996's Avatar
Default Check your fuel regulator vacuum line!
1996 SD 5speed, Safari gard front bumper, 90lb winch, 245/75 r16 Super Swamper Iroc
While tearing it down to do the heads I found that my fuel regular vacuum line had come off. I've been getting 10 mpg and considered this par. Truck has never given me any reason to check fuel system for any problems (although I should have anyway) No codes, no idle or acceleration issues, TRUCK HAS RUN PERFECT. Just thought I would throw this out there for those of you with lower than expected mpg. Hoping to get my 16 mpg after getting it back together...NO HATERS PLEASE! Let me believe until I get it back together.
On the other hand. Is there a reason the PO may have unplugged it because it was faulty, is this a temporary fix? Any way to bench test it?
Old Dec 27, 2015 | 01:09 AM
land44's Avatar
Hi there. Any updates on this? did it help with mpg?
Old Dec 28, 2015 | 08:30 PM
No, no such luck! Still holding steady at 10 mpg. Crazy thing is that 13 mpg sounds good to me now. On to the O2 sensors, then maybe the ford injectors if I can find the one that fit.
Old Dec 28, 2015 | 10:01 PM
TOM R's Avatar
Volvo skinney injectors from the 5 cylinder engine
O2; cheap ntk on amazon
Old Dec 29, 2015 | 10:02 PM
Coachgeo's Avatar
Year range and model of Volvo? Knowing this will make it much easier when dealing with helpless..... I mean helpful part counter clerks
Old Dec 31, 2015 | 07:32 AM
MM3846's Avatar
Meh, mine has been disconnected for over a year now. I still average 12MPG around town.
Old Jan 4, 2016 | 10:39 AM
Gimebakmybulits's Avatar
3 Year Warranty Genuine Bosch Fuel Injector Set 210cc Generation 3 | eBay
Old Jan 4, 2016 | 11:44 AM
TOM R's Avatar
In my build thread I probly list the part number ,I grabbed mine from a u pull
Old Jan 5, 2016 | 10:58 AM
TOM R's Avatar
Here is the injector 1275194
Do Google search they come right up
FlyingZebra34
Feb 22, 2014 05:39 PM
jocko1963
Sep 1, 2013 07:23 AM
zeropegleg
Jul 24, 2013 10:25 PM
leadfoot
Sep 13, 2009 09:51 AM
cold_surfer
Aug 15, 2009 09:59 AM
