Code help on 97 Disco
Old Feb 23, 2011 | 07:55 PM
wmjsajudge's Avatar
Default Code help on 97 Disco
looking at a 1997 disco engine light is on. And this code comes up=charging system= any idea what it is? Any help would be appreciated. Thanks warren
Old Feb 23, 2011 | 08:03 PM
wmjsajudge's Avatar
Actually its a 96 thanks warren
Old Feb 23, 2011 | 09:12 PM
XCELLER8's Avatar
exactly what code # are you getting ?
Old Feb 23, 2011 | 09:18 PM
You will not get a charging system code, if your battery or alt do not have enough juice your battery light on the dash will come on but you wont get a code.
Old Feb 23, 2011 | 09:19 PM
wmjsajudge's Avatar
P0138 charging system code?
Old Feb 24, 2011 | 08:51 AM
XCELLER8's Avatar
P0138.... " o2 sensor circuit high voltage ( bank 1/ sensor 2) "
you likely have a faulty O2 sensor.....driver's side BEHIND the cat converter
the front 02's regulate the fuel /air mix ......the rear O2's basically check the efficiency of the converters....
usually this code ...if it's the only one you have, would indicate a faulty sensor.....you should replace them both( behind the cats) instead of just one.. as you dont want to confuse the Rover Gods,
One way to check would be to switch the 2 rear sensors, side to side, and see if the problem follows the sensor
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
