Code help on 97 Disco
P0138.... " o2 sensor circuit high voltage ( bank 1/ sensor 2) "
you likely have a faulty O2 sensor.....driver's side BEHIND the cat converter
the front 02's regulate the fuel /air mix ......the rear O2's basically check the efficiency of the converters....
usually this code ...if it's the only one you have, would indicate a faulty sensor.....you should replace them both( behind the cats) instead of just one.. as you dont want to confuse the Rover Gods,
One way to check would be to switch the 2 rear sensors, side to side, and see if the problem follows the sensor
DiscoBenjamin
Oct 14, 2011 05:53 PM
Thanks warren
