Coil Spacer Lift front same as rear?
Do they have a hole in the center of them? They need one for the fronts for shock mounting. Have you looked at toddco suspension?
http://www.toddcosuspensions.com/landrover.html
The front and rear are different in that the front has a hole in the center for a shock. I run them under my OME lift springs with no problem. You can make your own all you need is some round aluminum stock 4" i think cut the desired thickness and drill some holes in them. I had to cut mine at an angle on the front so the springs would sit flat on the perches, basically the front is about 1.5" and the rear of the mount is about 1.25".
on
