Coil Spacer Lift front same as rear?
Old Feb 1, 2011 | 08:12 PM
Spencerfitch's Avatar
Default Coil Spacer Lift front same as rear?
I plan on downsizing my body lift to 1" and adding a 1" coil spacer.
Roverparts only sells rear, and im pretty sure they are the exact same as the front. Does any one know
Old Feb 1, 2011 | 09:05 PM
Chris-bob's Avatar
Yes, someone knows. Just not me...
Old Feb 1, 2011 | 09:11 PM
kenk's Avatar
Do they have a hole in the center of them? They need one for the fronts for shock mounting. Have you looked at toddco suspension?
http://www.toddcosuspensions.com/landrover.html
Old Feb 1, 2011 | 10:06 PM
WOW.... if only I would have looked... Better yet if only I would have THOUGHT.. about it..
Old Feb 1, 2011 | 10:07 PM
Thanks for the link they have better prices anyways!!
Old Feb 1, 2011 | 10:16 PM
Chris-bob's Avatar
Has anyone put spacers in? I thought about it but for a few hundred more, I can get a lift.
Old Feb 1, 2011 | 10:19 PM
lol I already have a lift [springs].. .....body lift....hell im gonna have every type of lift imagineable..
I need some seat lifts.
Old Feb 2, 2011 | 07:21 AM
Long Haul's Avatar
The front and rear are different in that the front has a hole in the center for a shock. I run them under my OME lift springs with no problem. You can make your own all you need is some round aluminum stock 4" i think cut the desired thickness and drill some holes in them. I had to cut mine at an angle on the front so the springs would sit flat on the perches, basically the front is about 1.5" and the rear of the mount is about 1.25".
Old Feb 2, 2011 | 10:01 AM
Chris-bob's Avatar
Good info to have. Thanks. Do they have to be aluminum? Can they be other materials? Would another material work better? I ask because I can have some made in almost any material...or is it best to just stick with aluminum.
Old Feb 2, 2011 | 10:08 AM
Long Haul's Avatar
You can make them out of any metal i guess. Aluminum is just easy to machine and its plenty durable enough. I dont think I would want to use poly or any kind of plastic or rubber.
Freedom38
Jun 26, 2015 10:37 PM
dobe1canobe
Jan 12, 2013 04:52 PM
Frank4
Jun 30, 2012 07:13 PM
blcp86
Jul 14, 2009 10:01 AM
malmberg
May 13, 2009 08:17 PM
