Continuing Education on the green devil
Well this weekend i swaped out my cooling system overflow tank and then moved onto examining my steering as it hasa little bit of freeplay in it and the occasional pop sound when hitting bumps or dips sometimes even on flat roads. The track rod ends all 4 are new, has new ball joints, new steering box. although it probably needs adjustinng. I was checking the wheels and noticed a small amount of movement when you pull or push the wheel in or out at the top and bottom its not bad jsut about a 16th of a inch play but havent had time to do the research as my work schedule is not looking good this next week so i figured I would ask around. everything I installed was torqued to specs using a digital torque wrnch and a aneedle one to. but my main concern is the popping sound and the slight movement up and down on the wheels its the same on both sides.
I'm taking it in for alignment soon but wanted to try and have it sorted out first.
1998 Land Rover Discovery Series 1 LSE
4.0 V8i
AKA: The Dreen Devil
4.0 V8i
bikingteacher
Sep 21, 2009 09:50 PM
ezikial4
Jul 17, 2009 08:47 AM
