Coolant bubbling out of reservior cap...
Old Sep 1, 2013 | 02:16 PM
Beamer1's Avatar
Default Coolant bubbling out of reservior cap...
I have a 98 Disco...I successfully performed the head gasket (rebuilt heads/guides, etc.) job six months ago. The oil is clean. Noticed that the exhaust is white Smokey, oil is clean so far..confused...should I do the chem test for blown HG?
Old Sep 1, 2013 | 03:39 PM
archaeology_student's Avatar
Uh oh, sounds like something may have been missed
Definitely test it to be sure, and how have your oil levels been?
I had a similar experience after my HG rebuild, and it turned out that the viscous fan clutch was failing and causing heat spikes and made the coolant leak out from under the cap.
The way to test the viscous fan clutch is to park the vehicle, turn off the engine, and try to spin the fan in front of your radiator by hand (let me stress, TURN OFF THE ENGINE BEFORE STICKING YOUR HAND THERE)... should barely spin or move like it has peanut butter inside (that's a good sign).
If it feels really easy to spin by hand or there is no resistance, then it might be time to replace the viscous fan clutch
Had my viscous fan replaced, and no more issues with the cooling system, no more bubbling from the reservoir cap. Learned this from all the great people on this forum!
Old Sep 1, 2013 | 03:45 PM
Beamer1's Avatar
Okay, will check. I did replace with the Chevy fan clutch. I have the black coolant reservoir, but a newer cap...should replace both? I'm getting white exhaust...the oil is clear, not muddy, as was previous...Do you know the name of the HG test kit that test radiator fluid? Yes, all the expertise in this forum has saved me. thanks to ALL...
Old Sep 1, 2013 | 06:32 PM
I am afraid if you have white smoke in the exhaust there is a problem. It is called an exhaust gas in coolant block test kit, a liquid that changes color when it "smells" exhaust gas in the coolant. Were heads machined? Or tested for flatness?
redrover75
Jul 21, 2015 01:07 PM
ninjabrianv
Nov 10, 2013 07:10 AM
tbesselman
Nov 19, 2011 11:02 AM
mackshawnd
Feb 28, 2009 05:44 PM
dickensheets
Nov 6, 2006 12:32 AM
