Cooling in Extremes.
Old Apr 13, 2013 | 07:41 PM
SSL9000J's Avatar
Originally Posted by bcbp
Just the clutch, unbolt it from the new fan. You'll need to drill the holes larger on the new clutch.
Actually it's the fan itself you'll have to enlarge the holes in. You'll also need four different bolts. (The Rover clutch is metric, the Chevy is SAE.) I think they're 3/8-16 by 1/2", don't quote me on it though.
Old Apr 13, 2013 | 08:05 PM
I trimmed my boneyard fan to fit the oem shroud. Not as much air moves without the shroud at low speed or idle. You have to be precise, as balance is involved.
Old Apr 13, 2013 | 08:36 PM
TOM R's Avatar
ok so I need to use the rover clutch and the chevy fan?
trim the fan to fit the shroud?
wouldn't it be better to trim the shroud so there is no concern with throwing the fan off balance and in turn ruining my new clutch and wp?
Old Apr 13, 2013 | 09:25 PM
I am running at this point oem shroud, oem water pump from a boneyard donor D2 (clean but not brand new), and clutch plus fan from 2000 Chevy Blazer. 10,000 miles so far. Trimmed fan. I tried various combinations of Rover fan and Chevy clutch etc. Settled on this because it moves more air.
see https://landroverforums.com/forum/ge...hlight=cooling
and https://landroverforums.com/forum/ge...ghlight=clutch
Old Apr 13, 2013 | 09:42 PM
No, you use the ROVER fan and the CHEVY fan clutch.
Buzz likes to experiment because he gets bored or something.
Old Apr 13, 2013 | 10:15 PM
Or to look at it another way:
Stock fan and stock clutch and stock shroud = normal use in most parts of the world.
Chevy clutch (save money) + stock fan + stock shroud = normal use and fixes most problems
Chevy clutch + Chevy altered fan + stock shroud = a little more cooling at low speed, no difference at freeway speed
No clutch and metal blade fan + stock shroud = more low speed cooling, less MPG
I have not compared the D2 fan on a D1 with the clutch, the D2 fan looks like it might also move more air.
One reason I did this was to show that salvaged parts could be used on a temporary basis. Not all boneyards are classy enough to have Rovers, but hard to find one without Chevys. Money is sometimes an issue, etc.
I'd love to find a substitute radiator, or alternator (besides the obvious Range Rover ones).
About this time the IBEF members usually wake up..... (International Brotherhood of Electric Fan-atics)
Old Apr 13, 2013 | 11:47 PM
CUpgt's Avatar
Bored and experimenting is what im cooking up! Dual electric fans from a Ford Probe GT. 14" and 12" pullers. Shroud is exact width of the Rover radiator and only a 1" shorter. Split the difference and you have a 1/2" gap at the top and bottom with a fully shrouded electric fan set up. And it helps that my DD is a Probe GT and I have a spare fan set up laying around
Old Apr 14, 2013 | 06:59 AM
bcbp's Avatar
Tom, I'm from SJ if you need a hand let me know. I did the Chevy clutch swap about 6 months ago.
Old Apr 14, 2013 | 09:33 AM
Shiftonthefly1's Avatar
I was wondering when someone was gonna chime in with the electric fan argument. I can't argue the logic as 99% of OEM systems are now electric.
I however, being the simpleton that I am, enjoy ridiculous simplicity. My trucks will always have a mechanical fan. Unless someone can show me verifiable data backing up a substantial gain in HP/MPG (like 15+horse and 7+mpg), I enjoy the reliability and simplicity of the mechanical fan.
As far as the Chevy fan, I'll try it. I'd rather cut my 5 dollar junk yard part then my Land Rover. I'm a huge fan of not cutting up my truck unless its absolutely necessary. I don't even like cutting the dash up for a radio.
Old Apr 14, 2013 | 09:44 AM
TOM R's Avatar
ok I purused the links above and see that the disco came with a 6 blade? mine has an 11 blade with rover emblem
ya'll are makin my head hurt or maybe it is from beating it on my rover lol
