Cosmic88....thank you (p1193)
Old 11-26-2010, 10:06 AM
XCELLER8's Avatar
Originally Posted by NiteTrain
xceller8, do you remember the ohm readings? I checked mine today..the one I suspect is bad was reading @ 12 ohm and the good one was reading @ 6 ohm
the sensor that gave me the P1193 code has NO continuity( open circuit) between the red(power) wire and the white(ground) wire.
the resistance between the yelow and black wires starts at 6ohm and slowly climbs to 18-20ohms as you leave the meter connected for a few seconds. I also tested a sensor that I "believe" to be good and it had the same resistance on the yellow / black wires(sensor circuit) as the bad one above, but had 6 ohms between the red & white wires(heater circuit)....hope this helps
Old 11-26-2010, 07:27 PM
Thanks for the additional information regarding the O2 sensor. Glad to hear you got it fixed.
calebbo
10-12-2011 09:54 PM
riggskwong41
01-07-2009 10:13 PM
luxury1
01-05-2009 02:44 PM
AnnelieseMae
08-20-2008 09:57 PM
MouseR
02-20-2008 08:14 PM
Quick Reply: Cosmic88....thank you (p1193)
