CPS shield?
Old Dec 4, 2018 | 04:09 PM
hrhoward's Avatar
Originally Posted by vanbadri
It was the cover!!!
That's awesome! ish
Don't let me scare you into selling it. As far as I can tell, I'm the only one I have heard of that has had the bracket welds break.
Old Dec 8, 2018 | 10:47 AM
partsguru's Avatar
Exclamation
I just went through this lovely maintenance task myself (and I am putting together a better post on my experience!), but I found my shield loose like yours and could not get a good view of the mounting bolt or feel the location with my ice-cold fingers in the parking lot! Knowing my 96 was sitting at home with all her guts, I grabbed onto it ..... and yanked! Broke it right off! But now I could see the bolts and removed my sensor - which was the assumption I was working on for my no start. Although I've sold it for years and had some in my box and never used it, I gambled on Gorilla glue to join the two pieces, lined up perfect and is still holding well. I had found a good illustration of the sensor under the Bosch system explanation, which helped but working on the ground in the cold was great fun. Even though harness wire was cracked - by the time I got it pulled off the sensor and up on top - sensor tested good (slight AC voltage when metal knife blade passed by it) - and harness repaired better than Rover (details later!), problem turned out to be inertia switch connector! Russ
bantham1
Sep 20, 2015 08:04 AM
philwarner
Mar 24, 2015 02:34 PM
lmcgrew79
Oct 5, 2013 07:34 AM
carlos84
Jan 10, 2012 10:22 PM
oljohnboy
Mar 30, 2009 08:54 PM
