Cruise control questions...
For those of you that have working CC, what does the amber light mean on the power switch after you engage it? Problem with the system or normal?
Also, can you hear the vacuum pump operating? Let's say with the engine off and key on...does the pump run when you depress the switch or does it only run when ECU senses you are over 30 mph?
I've got a new (used) switch in that actually seems to work and light up where my old one wouldn't but all I get is the amber light and I think there should be a green light too (when engaged?). Obviously the cruise is not working.
I have a new (used) ECU also (thanks Josh) but I haven't put that in yet.
Thanks!
Thanks!
