Cruise Control vacuum line routing......
Old Feb 16, 2011 | 02:23 PM
JBeezy53's Avatar
Default Cruise Control vacuum line routing......
The hose to comes off the T by the master cylinder and goes through the firewall............... what does that connect too? I couldn't find it in the Rave manual.
Old Feb 16, 2011 | 02:51 PM
Cosmic88's Avatar
Default brake switch
I assume you have an auto transmission...
It is in RAVE just hard to find I guess. That line goes through the bulkhead to a switch located near the top of your brake pedal arm. When the brake is depressed it opens the air line, removing the vacuum from the lines and causes the Cruise Control to let go of the Throttle. If you are limber just crawl into your footwell (on your back) and look up. You will be able to see where it passes through the firewall and then to the switch.
Old Feb 16, 2011 | 03:07 PM
JBeezy53's Avatar
Thanks mine has never been connected since I had it. I figured the brake pedal but wanted to be sure before I crawled under there. I'm 6' 1", 220 lbs with long arms so its not the easiest thing to do but doable. Thanks.
Old Feb 16, 2011 | 07:18 PM
blackcloud's Avatar
Oh, a little guy... 6'8" 270 lbs Which by the way strikes me as funny because of all the guys switching seat rails around and the like to gain legroom. I have a 36" inseam and no issues with legroom in a Disco. Btw, when you go to check the cc brake switch, you're gonna wish for another elbow about half-way up your forearm (speaking from experience).
mj_duell
Oct 19, 2011 03:43 PM
flacsrover
Sep 4, 2010 11:19 PM
Rover Chris
Jan 7, 2010 09:17 PM
OlDood
Jul 13, 2007 12:24 PM
danepeople
Oct 17, 2006 10:10 AM
