CV Joint - Cost
Old May 1, 2012 | 04:56 AM
LJW2012's Avatar
Originally Posted by yoshibond
Am I correct in thinking the two links you posted are together what I would need for the job (obviously X 2 each)?
I've been reading this and that's the way that i've taken click to see to mean!
Old May 1, 2012 | 09:07 AM
Jake1996D1's Avatar
Yoshi - How did those CV's work out that I sent you? You all good and back on the road now?
Old May 1, 2012 | 10:39 AM
Makes sure you replace the wheel bearings and seal, in all 4 wheels, at the same time if they are showing age, other wise clean and repack them.
Old May 2, 2012 | 11:51 AM
yoshibond's Avatar
Hi Jake - the CVs looked fine and seem to work okay. Although when taking apart I found that the needle bearing on one of the wheels was broke apart and missing pins and the ones still there were almost square (the random pieces of metal in there is likely what killed the CV in the first place I thnk) .... So i had to order that and wait...
Then when reassemblying with that all seemed to get back on okay but then we noticed one of the brake pistons was leaking and now are awaiting replacement parts for this ....
But yeah - the old CV was sticking and very hard to move vs new ones were nice so I think it will have fixed the problem. Will keep you posted.
Old May 2, 2012 | 04:22 PM
Jake1996D1's Avatar
Sounds like my truck.. Once every 6 months or so I dig in to make sure everything is good otherwise when one thing goes you're fixing a whole bunch of stuff. Best of luck in finishing it all up!
Old May 2, 2012 | 11:34 PM
yoshibond's Avatar
Thanks. Will let you know how it works out when it's all done.
s4lex
Mar 21, 2007 09:19 PM
RichieRich
Dec 10, 2006 11:20 PM
mackdoyle
Sep 29, 2006 08:41 PM
surf9ska
Feb 14, 2006 03:52 PM
Charlie L
Mar 10, 2005 12:52 AM
