D1 96-99 GEMS Best4x4 PCV Mod:
Old Mar 31, 2025 | 06:02 PM
  #21
Best4x4's Avatar
Sure would like to know how you are pulling the OEM baffle out so easily. They literally crumble when trying to be removed unless your just removing the entire metal tube from the valve cover and tapping it back into place.
Old Mar 31, 2025 | 08:24 PM
  #22
jastutte's Avatar
Originally Posted by LKNSB
Because during 5,000 miles nothing builds up on the stock baffle. Which leads me to believe the Honda PCV is too small. The fact it cause some leaks due to being clogged as well, is something I don’t want to be forced to keep an eye on constantly.
huh? haven't had any issues with it on any of my Discoverys. but, you gotta do what works for your engine.
Old Mar 31, 2025 | 09:21 PM
  #23
LKNSB's Avatar
7th Gear
Vice grips to grab the tip of the baffle, and just pull up with a slight consistent force. Comes right out
Old Apr 2, 2025 | 02:57 PM
  #24
Harvlr's Avatar
I did the PCV mod on my ‘97 P38. It works great, but also I didn’t seem to have any trouble with the original system. The baffle was clean and it pulled out easily and intact. Having a PCV valve seems to be the right thing to do.
Old Nov 10, 2025 | 09:29 PM
  #25
Sanch2000's Avatar
New Member
Well I finally had some time to look into which PCV valve would work with a D1 without doing any modifications. I've come across the FRAM FV368. As with my D2 mod remove the plastic baffle from the valve cover then just simply cut the OEM rubber line in the middle from the valve cover to intake and insert the FV368 inline in the proper flow direction and you're all done. Should work identical to the D2 Best4x4 PCV Mod. Sorry it took me so long to look into it, but I've been really busy lately. I had a lot of request for a D1 Best4x4 PCV Mod and now it's here.
**94-95 D1's use a huge metal mesh flame trap style PCV setup and doesn't need improvement IMHO like the 96-99 GEMS setup.**
FV368 (95 Honda Passport with the 3.2L V6)
Thanks for the mod! 🤙
Replacing the Baffle gave me the P1178 code.. this mod cleared it and it’s all smooth sailing.
99 Disco 1 SD
Best4x4
Jan 18, 2022 04:46 PM
Best4x4
Dec 17, 2021 12:27 PM
JoJo The Giraffe
Nov 8, 2021 01:52 PM
andino
May 18, 2021 12:27 PM
piperff
Sep 7, 2018 12:38 PM
