D1 exhaust pipe size?
Old Jun 6, 2011 | 05:55 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Default D1 exhaust pipe size?
If I'm measuring correctly, the Y-pipe is 2'' OD and the muffler to resonator is somewhere around 2 3/8''. Does this sound right?
Old Jun 6, 2011 | 07:30 PM
turf63's Avatar
2.5. When I bought my muffler I went with 2.5
Old Jun 6, 2011 | 07:31 PM
turf63's Avatar
As per the almighty spike
Old Jun 6, 2011 | 07:33 PM
turf63's Avatar
Inlet and outlet. Sorry can't edit posts from my phone.
Old Jun 7, 2011 | 06:34 AM
Jull's Avatar
After the y pipe the exhaust is 2.5 inches wide. The y pipe on my truck was close to 3 inches. I had to search for a 3 inches flange when mine broke off. I don't remember the size of the cats though.
Old Jun 7, 2011 | 07:26 AM
LRD2&ME's Avatar
2.5'' size after the flange, alright thanks. Going to weld in a couple high flow CATS, loose the resonator and move the muffler back and add a nice tailpipe.
Old Jun 7, 2011 | 08:28 AM
turf63's Avatar
I need a welder. What are you using MIG? Wish I knew how to tig weld. THAT looks useful
Old Jun 7, 2011 | 12:52 PM
geek_IM's Avatar
I just got done welding in new cats and let me tell you it is not a job for the faint of heart. If you want a blow by blow I can oblige, but judging from your past posts I am hoping you will have serious help.
First of all, the y pipe tubing is closer to 2-1/8, if you get 2 it will be too tight.
Second, the aftermarket cats are longer than what you will cut out and cause some geometric problems when putting it all back together.
Third, the cat inlets and outlets are very thin compared to the y pipe and is very tricky to weld.
Fourth, the pipe pulled allover the place when I took it out and welded it, even though I very carefully control welded it once it was out of the truck.
Good luck, I have pics etc but seriously don't thunk this is a 1-2-3 done job
Old Jun 7, 2011 | 02:23 PM
LRD2&ME's Avatar
Over twenty five years of welding experience, railroad pump repairman, Marine Corp heavy equipment mechanic, life long auto mechanic, NO PROBLEM. Anyways, I'm convinced that the Y-pipe is going to have to go. I'm going to just run new pipe as duals all the way back. I'll salvage the pipe to exhaust manifold and just weld all the way.
Old Jun 7, 2011 | 02:48 PM
turf63's Avatar
Sweet. Then come do mine too!
Francopacks
Feb 15, 2023 07:08 PM
RDB
May 22, 2015 06:49 AM
twaszak
Jul 15, 2012 07:21 PM
Chrisinhouston
Dec 23, 2007 10:26 AM
gwalker
Apr 14, 2007 12:03 PM
