D1 Finishing touch for alpine windows trim panel
Old May 4, 2021 | 11:25 AM
Pierrodisco's Avatar
Question D1 Finishing touch for alpine windows trim panel
Hello,
I’m just wondering what’s the exact finishing from the alpine windows sealing gasket with the surrounded interior trim panel.
The sealing gasket round the alpine window has 2 inner lips, a larger outwards (to the exterior of the car) and a smaller inwards (to the interior of the car. The “exterior” fits on the flenge of the outcut for the window in the exterior bodypanel. Ascso far all is very clear to me (and everybody).
But… where does fit the interior lip ? Is these fit around the edge of the opening in the inner trim panel (just as for the rectangular window just beyond) ? In this case there’s no more chance of air circulation between car interior and cavity between inner trim panel and outer body panel.
Or is these lip simply bend against the outer body panel and is the inner finishing trim panel simply placed “against” the lip.
Take just a short look A-at the alpine windows on the interior of your Disco 1 and give me a short answer.
Inner lip fits round edge of trim panel. Is this the correct fitting ?
Thanks !
Much greetings,
PierroDisco
Old May 4, 2021 | 04:49 PM
jvarnadoe's Avatar
Mine have a slight gap between the plastic panel and the gasket.
Old May 4, 2021 | 07:27 PM
disco96sd's Avatar
well certainly years of weather - dry climate humid climate - garage - outside etc. will affect the rubber gasket of anything
if this is a replacement and you are wondering about the fit vs original - ask the Chinese
Old May 5, 2021 | 03:40 AM
Wink Replacing window gaskets above boot floor
Hello,
It was indeed already a replacement when I bought the Disco in 2012. The gaskets ware more black coloured and very shiny, without any cracks in the corner from bending.
In 2013 I replaced the gasket from both rectangular windows above the boot floor ; they both were more gray coloured, not shiny and with a great crack in all four corners. The same story for the window gasket in the back door.
Much greetings, and thanks for the info !
PierroDisco
keninnc
Apr 20, 2021 09:07 PM
harryashley
Apr 23, 2017 08:12 AM
timothycwright
Jun 1, 2014 03:37 PM
sinebubble
Dec 11, 2009 02:07 AM
mcbenavidez
Nov 7, 2005 02:46 AM
