Tip needed for interior door panel trim top piece re-install
Old Apr 20, 2021 | 02:26 PM
keninnc's Avatar
Default Tip needed for interior door panel trim top piece re-install
I need a tip or advice to re-install the top piece that is on top of the interior door panel.
Ever since I put the door panel back on this piece will not stay attached. Every time the glass is raised back up it comes loose.
Is there a trick to setting the tabs? I'm assuming that the door panel goes on first and then this piece that fills in the gap between the panel and the glass.
Thanks,
Old Apr 20, 2021 | 09:07 PM
04disco2va's Avatar
I’ve done this a few times and it worked best for me to start the top piece making sure the clips straddle the top edge. For me sometimes I thought clips were in right but weren’t. Line up the door panel and get it started almost fully in, just past edge of the top piece where it comes down. Seat the top piece fully and then door panel.
emncfi
Sep 23, 2024 09:24 AM
emncfi
Dec 25, 2016 02:55 PM
timothycwright
Jun 1, 2014 03:37 PM
cationmoted
Dec 4, 2010 08:55 PM
fcfinc
Detailing
Nov 1, 2006 06:20 PM
