D1 TPS, fuel temp and O2 malfunction *solution*
Posting this for reference for any future searchers.
I was having an issue with my ScanGauge not communicating with the O2 and TPS sensor. I also had pending codes for high or low circuit voltage with fuel temp sensor and tps sensor. Randomly once it had a jumping idle but it didn't do it again.
Solution: check middle red plug on ECU. Turns out the vehicle can run just fine with that plug undone.
Hope it helps someone
BloodyShirt
03-25-2015 12:08 PM
