D1 TPS, fuel temp and O2 malfunction *solution*
Old Feb 6, 2017 | 12:02 PM
RedRovin''s Avatar
Default D1 TPS, fuel temp and O2 malfunction *solution*
Posting this for reference for any future searchers.
I was having an issue with my ScanGauge not communicating with the O2 and TPS sensor. I also had pending codes for high or low circuit voltage with fuel temp sensor and tps sensor. Randomly once it had a jumping idle but it didn't do it again.
Solution: check middle red plug on ECU. Turns out the vehicle can run just fine with that plug undone.
Hope it helps someone
Old Feb 8, 2017 | 08:28 AM
WaltNYC's Avatar
Thanks for following up
atancreti
Sep 23, 2016 10:01 PM
BloodyShirt
Mar 25, 2015 12:08 PM
TRIARII
Oct 5, 2011 08:34 PM
spanky melton
Mar 30, 2011 10:57 PM
alanroberts50
Sep 5, 2009 03:00 PM
