D2 lift on a D1
Old Sep 16, 2014 | 02:36 PM
swak6287's Avatar
Default D2 lift on a D1
Can I use a 3" D2 lift on my D1 (discovery)? Anyone? Anyone?
Old Sep 16, 2014 | 03:45 PM
Richard Moss's Avatar
....and on a similar theme, can a D1 lift kit be fitted to a D2?
Old Sep 16, 2014 | 04:12 PM
TOM R's Avatar
I believe d1 to d2 no
D2 fronts fit on d1 rear maybe, there have been threads on this
Old Sep 16, 2014 | 04:55 PM
swak6287's Avatar
I think I will just stick with the D1. Now, 2" OME will gimme 1 1/2 inch? LOL
Old Sep 16, 2014 | 05:08 PM
TOM R's Avatar
Depends the weight you buy, HD 2" ome like mine has will over lift without the required static weight
Think its 150 lbs front 100 rear? More weight nicer ride awesome ride off road loaded down, I run bilstein, but OME shocks are supposed to be nice too
Old Sep 16, 2014 | 06:40 PM
MM3846's Avatar
the shock mounting setup is different on D1 vs D2. front coils are prob the same, rears in a D2 i'd imagine are stiffer.
Old Sep 16, 2014 | 08:18 PM
fishEH's Avatar
D1, D2, RRC, D90 all use the same diameter coil springs. They will all interchange with eachother. Some vehicles will see more lift from the same springs than others. D2 Resr lower spring perches are deeper than D1 perches. D2 owners often swap in the D1 perches to see an extra 1/2" of lift. There is pretty much nothing that can't be accomplished with some combination of springs, perches, and cheap aluminum spring spacers.
Shocks on a D2 are different from a D1 all around.
Old Sep 16, 2014 | 10:04 PM
Thanks for the info. Fitting the D1 spring mounts to a D2 for an extra 1/2" lift sounds interesting because I'd like just a litle bit extra (it already has bigger tyres and I don't want to overdo it).
Old Sep 17, 2014 | 08:35 AM
swak6287's Avatar
I knew we have a bunch of garagengineers here. Thanks so much for the info, guys
Old Sep 17, 2014 | 10:41 AM
fishEH's Avatar
You may have to open up the two mount holes on the lower perches. Can't recall for sure. Nothing 2 minutes with a drill bit can't fix though.
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
