dash/parking/headlights
Old Jan 27, 2018 | 05:43 PM
mmterrill98's Avatar
4th Gear
Default dash/parking/headlights
im having an issue when i turn on the headlights on a 99 land rover discovery I. when the headlights come on the dash and parking lights go off. also the passenger light is really dim for some reason too. is there any ideas? i never ran across this issue before.
Old Jan 27, 2018 | 05:45 PM
4th Gear
when i mess around with the switch i can get them to work at the same time occasionally but the one headlight is still dim. didnt know if theres a way to tear apart the switch to clean it.
Old Jan 28, 2018 | 12:06 AM
Icannap1's Avatar
A dim light can be due to a bad ground for that light or a bad bulb. Try swapping the bulb from one side to the other if the problem is still on the same side check the ground to the side that is not working properly.
Old Feb 4, 2018 | 06:17 AM
4th Gear
i keep working with the switch and got the headlight to stop being dim. the parking lights and headlights will stay on if i get it in a certain position on the switch which really makes me think it needs cleaned. does anyone know how to tear it apart and hit it with some electronic cleaner and grease?
Old Feb 5, 2018 | 09:36 AM
WaltNYC's Avatar
clean and repair guide here...
https://landroverforums.com/forum/di...mantled-55964/
Old Feb 5, 2018 | 09:41 AM
whiskeynipple0088's Avatar
my headlights were dim due to a cracked-semi melted connector. replaced the connector (and last 3 inches of wire) with a generic - all worky every since.
Note the 3 inches of wire was included in the kit and was larger gauge.
Nunezjoel13
Jan 28, 2018 06:31 PM
tibyABv6
Dec 18, 2012 10:09 PM
soundstream11
Nov 14, 2011 03:37 PM
Street Wolf
Sep 27, 2008 08:58 AM
tonyzp007
Jan 26, 2007 11:21 PM
