Daytime running lights
Old Jan 2, 2012 | 01:18 PM
Roadbacon's Avatar
3rd Gear
Red face Daytime running lights
I have a 99 disco series 1. The daytime running lights do not come on when the vehicle is started. Checked the fuses and they are okay. Checked bulb, okay. The running (dims) only come on when you turn the light switch to that position. Is this an easy fix? I have limited vehicle skills.
Old Jan 2, 2012 | 05:12 PM
I assume you do not live in the US as the DRL's were not fitted to those sold here.
There is a DRL relay that you need, I do not know its location.
Day Time Running Light Relay | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
Old Jan 3, 2012 | 09:08 PM
Roadbacon's Avatar
3rd Gear
Thanks, I'll do some research to see where it's located and ask around for the part.
Old Jan 3, 2012 | 09:56 PM
It is called a daytime running light control unit. See attached pages from RAVE.
Looks like a diode is also part of that. So was your vehicle ever set up with these (Canadian)? If it was, you would also want to check fuse F2 (20 amp) in underhood box and F1 (15 amp) in fuse panel under dash.
File Type: pdf
File Type: pdf
Old Jan 4, 2012 | 08:34 AM
DiscoBlanco's Avatar
Mine does the same thing. I thought that was the way it is supposed to be.
Old Jan 4, 2012 | 09:22 AM
Once you add the required parts you will still need to go to a dealer or shop and use a Test book to program your BCU to turn the lights on.
Old Jan 4, 2012 | 05:14 PM
Roadbacon's Avatar
3rd Gear
Thanks for all the manuals. Yes It's a Canadian Disco. Once I find the part and replace it, are you saying that my lights won't work. That's why I would have to take it to the dealer?
I was trying to get away from going to the dealer. Otherwise I would have them do the whole job.
Old Jan 4, 2012 | 09:04 PM
On the DI all you need to do is install the relay.
On the DII the dealer has to turn the DRL's on/off in the body control unit but not the DI, which is what you have.
Old May 26, 2013 | 11:25 AM
123mct's Avatar
8th Gear
I had the same problem and to save you going through the RAVE manual...the daytime running light relay is located under the passenger side foot-well. You will see a section of back trim, pull the locking tabs out and drop the trim down. You will then see the heater fan, just to the right of the fan you will see relays. It will be the second one in towards the fire wall, it will be marked Hamsar; Model H5002B. It will probably be hot to the touch if it has shorted out, you can test it with a multi-meter/ continuity test. Just look it up on you tube if you don't know how to perform it.
DaveBFoto
Dec 1, 2010 02:12 PM
sbest80
Jul 3, 2008 02:12 PM
Rioja Red
Oct 30, 2007 02:06 PM
SmooveB23
Oct 17, 2007 08:10 PM
oncorhynchus
Jan 21, 2007 02:28 PM
