Death Wobble part 2
Old Aug 7, 2015 | 07:40 PM
ihscouts's Avatar
Originally Posted by antichrist
Interesting. Not normal for them to provide part numbers in the shop manual, but does anyone actually run OE shocks?
Funny you should ask. Main duty is on pavement, work, chores, military requirements and vacations. Heard many complaints of stiff suspension with aftermarket. Highway ride is Caddy smooth, off road is not bad, little soft.
Old Aug 8, 2015 | 05:50 AM
antichrist's Avatar
I was kidding about the OE shocks, I'm sure a lot of people use them. Or at least shocks with pretty much OE specs.
Old Aug 8, 2015 | 08:06 AM
ihscouts's Avatar
I laughed, no worries.
Old Aug 8, 2015 | 11:20 PM
binvanna's Avatar
Panhard rod bushings. The panhard rod locates the front axle laterally and if the bushings are shot, it will wobble at speed. The radius arm bushings locate the axle longitudinally, so they are less likely to be the cause of side-to-side wobble, but if they're worn enough there can be enough play there to cause it.
Old Aug 22, 2015 | 10:26 PM
georgep's Avatar
Originally Posted by geek_IM
Listen this is going to dredge up all the death wobble trolls so let me be the first troll to chime in.
Death wobble comes from one thing - slop somewhere in the front end. I call BS on the whole swivel ball preload thing. Unless there is slop at the swivel pins, no wobble. So solving the issue comes down to finding where your slop is.
I replaced a LOT of things in my front end trying to rectify this situation. Did the preload thing with the fish scale three times and it didn't make a damn bit of difference. Replaced everything around the swivel ball and also had no effect.
So, what did I do? I replaced all the bushings front and back and it WENT AWAY. Specifically, the stack of rear bushings on the front radius arms were shrunken and hard. When I got underneath with a spud (something I suggest you do ASAP) and started prying around on stuff I could move the front around close to half an inch in any direction.
Now, everybody is going to jump on me because they say it says in the RAVE that it is due to the preload. It really doesn't. It mentions NINE other things to check, before a casual mention of "check the resistance and condition of the swivels".
Take a look yourself, page 5 of the Steering section in RAVE, see attachment. Or waste your time with the fish scale barking up the wrong tree. Up to you.
Go right ahead and ban me Disco Mike for disagreeing with you. You have threatened it several times before - now's your opportunity to follow through.
Preload was DONE by a rover person from the dealership (retired). I am 99% looking at the bushings on the radius rod. That is ALL that was not changed when we did the front end. I just bought a D2 so the D1 is parked till I get back to it. I think you folks have nailed it AGAIN!
Old Aug 22, 2015 | 10:30 PM
georgep's Avatar
Thank you all, Will look at the Panhard but I think that was also put in new when this problem came up.
Thank you all for your time on this.
Old Aug 23, 2015 | 07:32 AM
antichrist's Avatar
Have you read, and performed the steps, in the link in post #7?
Old Aug 23, 2015 | 05:29 PM
jimvw57's Avatar
I checked everything and the only thing I found was that I was able to move the wheel in and out at 12:00 and at 9:00 position. I replaced the pivot bearings, and *****(and seals) as the surface of the swivel ***** were rusted and pitted badly causing the lubricant to leak out, and wearing out the pivot bearings. (also not too good for the CV joints) I couldn't get any play in any of the other points using a pry bar. Wobble went away after new bearings.
Rover Chris
May 23, 2015 02:13 AM
Rover Chris
Sep 25, 2010 09:55 PM
blaze98
Sep 21, 2010 07:14 PM
mrcrptguy
Apr 9, 2009 06:02 AM
pelias
Sep 8, 2008 09:47 PM
