Defender hub seal on Discovery
Old May 3, 2016 | 03:21 PM
Fenix's Avatar
Default Defender hub seal on Discovery
Can anyone confirm this part number for the Defender hub seal that also fits a Discovery? FTC4785
Supposedly better than a Discovery seal
Old May 3, 2016 | 04:51 PM
fishEH's Avatar
RTC3511. I know it by heart.
Old May 4, 2016 | 10:04 PM
Fenix's Avatar
It's more resistant to water and grit?
When installing it, how far does go in or does it sit flush?
Old May 5, 2016 | 06:43 AM
WaltNYC's Avatar
See post #3 on this thread. In fact, the whole thread should be quite useful to you.
https://landroverforums.com/forum/di...earings-44462/
Old May 5, 2016 | 01:31 PM
Fenix's Avatar
The link says install to a depth of 4mm but I was told that this one actually sits flush. Which one is it?
Old May 6, 2016 | 06:44 AM
loanrangie's Avatar
The RTC3511 is the seal you want to use, it has a lip so needs to be seated with the top of the lip flush with the outer edge of the hub.
The body of the seal is then 4mm approx. below outer hub edge.
Not so much better for water or dirt ingress but being double lipped is better for oil lubed bearings.
Old May 6, 2016 | 07:22 AM
Fenix's Avatar
Awesome, thanks! Just placed my order.
NiteTrain
Sep 20, 2011 03:36 AM
Disrover
Aug 21, 2009 09:47 PM
jycsalas
Oct 29, 2008 03:01 PM
98xc800
Sep 30, 2008 04:51 PM
01 Discovery
Dec 1, 2006 12:07 AM
