Delayed crank, no power to fuel pump
Check for power as soon as ignition switch tuned to position 2. No power to pump and fuel pump relay doesn't close. I disassembled another MFS and manually closed the fuel relay and the fuel pump turned on.
Engine cranks with starter but doesn't start or continue to run. Manually closed fuel relay to turn fuel pump on and cranked with starter but no ignition, no spark.
I thought it was a USA model, based on what I was told when I bought it from 2nd owner (original owner from S. Florida). Has an Aussie emblem on grill but thought that could have been added later. Can I confirm country of origin using VIN #? If it was spider related I wouldn't be able to activate starter motor, correct?
VIN check using CalVIN indicates assembly location in UK. I suppose this means that the Spider is back in play? See VIN check results below:
SAL Manufacturer code: Land Rover
J Model: NAS Discovery, 200/300 Series
Y Model specification: 49 state emissions, 100in
1 Body type: 5-door, closed (station wagon, hard top)
2 Engine type: 3.9 litre V8 petrol, or 4.0 litre V8 petrol (OBD II)
4 Steering, transmission, GVW: Left-hand drive (LHD), 4-speed automatic, 6000lb
0 Checksum code: checks out ok
W Model year: 1998
A Assembly location: Solihull, UK
W Model year: 1998
have you checked the ECU , mounted strategically on the rh fenderwell so as to eventually absorb all the moisture and corrosion possible ?.....many of us have had issues with corrosion inside the ecu case.....it's not a big job to remove it and take off the covers to check / dry it out.....if it's wet or corroded....that alone will f-up a lot of things
Yep, no Check Engine Light on Dash in Pos III is a big giveaway to a pooped ECU. I believe XcellerGreat there was mention of a another ECU to swap in this lump of a wiring fur ball. Besides checking for corrosion I would be tossing the other one in just to make sure it's NOT an ECU issue.
I already removed and disassembled the ECU. One of the connectors was corroded so I cleaned it it (both M & F) and it looks fine now, though I can't be sure if any pins are missing. The inside looked remarkablly good, IMO. No moisture, no burn marks, no cracked or broken circuits (from what I could tell, though admittedly I'm far from an expert in electric circuits).
It was my understanding that one cannot simply swap out an ECU without having some reprogramming performed. Is this true?
Paul Grant or Will Tillery
Paul is; http://stores.ebay.com/Classic-Rovers
classicroverparts@gmail.com
paulgrant@mac.com
Will is; info@rovaguy.com
paulgrant@mac.com
