Did e-fan mod.. but discovered something.
Old Jan 4, 2011 | 06:49 PM
Spencerfitch's Avatar
Default Did e-fan mod.. but discovered something.
I went to the junk yard and picked up two taurus fans for 24$. Well mines from a 98-99. After getting home I realized mines completely different from the normal 3.9 taurus fan. Finally got it all mounted up and all. Its alot harder to mount than a 3.9 fan, because you have to make supports whereas the 3.9 fan comes attached to a shroud. It only took the fan a few bolts and 36" of 1/8 flat ss metal.
Anyways, many of you already know this but. Its about 70* here today and I have rode around all day picking up parts with absolutely no overheating issues. Actually temperature never got past 191* but averaged 184*
I can remove my whole fan with 4 bolts. I still need to get it wired up. I install was still super easy. I used two holes on the chassy and two holes on the top of the radiator.
I couldn't feel much of a difference without fan but the lod on my scangauge was considerably lower. And that should equal better gas mileage. With gas heading to 4.00$ a gallon Im gonna need it.
Old Jan 6, 2011 | 11:23 AM
Chris-bob's Avatar
How is the cooling with the taurus fans?
Old Jan 6, 2011 | 02:01 PM
Well.. It's still not hooked up.. No need for them temperature is fine without themz but it'll get hooked soon.
The_OGCJR
May 25, 2014 07:49 PM
CCRovers
Jan 30, 2013 11:01 AM
TRIARII
Dec 21, 2012 07:00 PM
2000 DII
Dec 4, 2008 08:07 AM
sloppyjoe
Nov 13, 2008 07:40 AM
