Diesel conversion for a `98 Discovery
Old Oct 2, 2014 | 10:46 PM
Dach Savage's Avatar
Default Ebay LR Diesel kits
Originally Posted by drowssap
there not priced that bad hes getting from a bone yard but everything is there he even has r380 convertions too. I was looking at a p-38 - bmw diesel convertion he had it was like $3500
I have been checking Ebay regularly for the last couple months, never seen anyone selling a LR diesel or LR conversion parts. Do you have any contact information for this party? I was talking to a Land Rover repair shop owner Saturday and he told me he just had a similar setup shipped over from UK and was anxiously awaiting its arrival. The engine is rebuilt and he figures he has about 9K in it before duty and customs fees. Also he he is a little nervous as apparently its a crapshoot as to whether it will clear customs or not. If it doesn't it gets sent back or scrapped. He had a OM617 that he was going to put in his P-38 and decided that he wanted the factory setup and it would be more valuable when done.
Old Oct 2, 2014 | 10:51 PM
Default OBDll concern
Originally Posted by fishEH
98's are also OBDII and subject to emissions testing in parts of the country that have it. That basically means it will not pass emissions in those states because the OBDII won't jive. 94-95 Disco is where its at for pretty much any engine conversions.
Yes the OBDll issue is definitely something to consider. Frankly didn't think about that. I can register my Disco in Yavapai county which doesn't have an emiss test program but this might be an issue if I ever went to sell it. Hmm, I wonder if there isnt a way to reprogram it to ignore missing inputs.
Old Oct 2, 2014 | 10:54 PM
nuclearw's Avatar
You would have to get an engine from that year or newer with an OBDII already setup .. but that would be replacing the ECU and other components... I dunno if fthe ECU contains the vin # somewhere too, smog checking is the bane of any engine swap
Old Oct 2, 2014 | 11:19 PM
Default LS swap
Originally Posted by MM3846
ok, so you do one windshield deep water crossing a year, which a LS with a snorkel and waterproofed electronics can do (same w any gas motor); and then you suffer all of the other 364 days a year with an anemic old clunker of an engine that struggles to maintain 70 mph, is a pain to find parts for, and gets only 4-5 mpg more than a LS.
no thanks. for $1500 i can have a running 5.3, 4L80E and all of the wiring for it. drop a tune in it, and i'll have close to 300 crank hp and get at least 20 mpg on the highway.
Each to his own on the gas/diesel argument. For me I like the low end torque and 25 mpg aspect + I have yet to talk to anyone that is successfully making his own gasoline but there are thousands of people around here making their own biodiesel. This Mitsubishi engine is rated stock at 165 with its peak torque at 1,600 rpm, if I wanted 300 Hp that can be done by turning up the pump and playing with the turbo. Plus I kind of doubt 20 mpg would be likely with an LS engine. FWIW I did look at the LS conversion idea and also have not found anyone that has done one successfully or not. This said the possible advantage of an LS conversion might lie in the OBDll issue.
Old Oct 2, 2014 | 11:53 PM
Default OBDll concern and ECU swap
After my first post on the OBDll question I got to thinking that maybe a an ECU from a UK `98 diesel disco might be the trick? They are OBDll arent they? Or did the brits do something different regarding their emissions. I am going to call the AZ MVD emiss compliance dept tomorrow too, see if there is a waiver or a way to re-certify the vehicle as a diesel. Might just be a matter of changing the fuel on the title and having it inspected manually. Might be a cluster**** too. The idea of being forced to stick stupid money into this 4.0 just to make it reliable and then having a truck that would not bring the cost of the engine if I wanted to sell it chaps my ***.
Old Oct 3, 2014 | 07:08 AM
MM3846's Avatar
there are a few defenders out there with a LS, and there is a guy on this forum with a LS in a LR3. Low end torque? try 315lb/ft for the earliest, lowest output 5.3, to 400lb/ft in 6.0s.. and thats stock, expect well north of that with add-ons and a tune. Corvettes get 30mpg STOCK on the highway, my buddy got 15 mpg towing a trailer cross country in a LS swapped '78 J10 on 40" tires. so yes, 20 mpg is more than achievable.
Old Oct 9, 2014 | 09:52 AM
film842's Avatar
For whatever it's worth, I'll chime in since I'm also looking hard at a diesel conversion for my 02 Disco. I've been quoted a price of 9k that would put a TD5 in, complete with five speed manual transmission and all electrics working. That seems like a hell of a good price to me and I happen to trust the shop that made the quote. The only part that I haven't figured out yet is how to get it through emissions testing.
I understand that it can and has been done here in Oregon, but I haven't confirmed it yet.
Why do I want a diesel? Just read the last sentence of Dach Savage's post above. That plus I'm tired of waiting for my engine to implode. (140k)
roverdisco1017
May 5, 2021 09:56 AM
KBW
Jun 13, 2012 06:16 PM
dreager1327
Aug 8, 2009 12:15 AM
johnkbl
Oct 25, 2007 07:32 PM
SDSlowhand
Sep 27, 2007 08:18 PM
