diff lock not working?
Old Oct 23, 2010 | 03:50 PM
booper169's Avatar
Default diff lock not working?
i can move the lever up and down into high and low but it wont move to the left.... when i got the disco it wouldnt even go up or down so i took the console out and lubed it all up.. but i still cant get it to go into diff lock? whats the best lubricant to use? also when the console and everything is out it looks like its supposed to slide on a little shaft when you move it to the left... mine wont budge....
Old Oct 23, 2010 | 03:58 PM
Danny Lee 97 Disco's Avatar
I did an extensive teardown and repair on mine. I posted some info on another site but that was three years ago, let me do some review and I'll see if I can find a link for you.
Old Oct 23, 2010 | 04:23 PM
Default Found It.
Here is the original write-up I did when I did my CDL Teardown/Rebuild.
Check out the Ex-MOD on the referenced site.
Link: http://www.fplrg.org/forum/viewtopic...aebbd50e92c75a
Here's a shortcut to just the pics I took.
http://rides.webshots.com/album/561754980PeQtRI
As I recall, the first time I actually got it to move side to side, even after all the teardown and reassembly, I putan extension on a speed handle with whatever size socket it was and rotated the nut in the middle of what I call the "Pivot Point" down at the bottom of the linkage right at the transfer case. I was trying to remove the nut, thinking I needed to tear further into it, and attempting to loosen the nut actually moved the shifter from unlock to lock. After working it back and forth a few times, it finally moved smoothly, but the CDL light still would not come on. I ended up having to replace theCDL switch as well. The internal plunger was corroded and the switch failed.
With New Switch and all the linkages lubed well, my CDL shifts " Smooth as Butter".
Take a look at these pics, it's the triangular plate at the bottom of the pics.
http://rides.webshots.com/album/561941781dIDDCp
Hope that helps.
Old Oct 23, 2010 | 04:34 PM
booper169's Avatar
what nut are you refering too... do you get at it from the top or under the truck?
Old Oct 23, 2010 | 04:46 PM
Do you still have your console out? Look straight down the CDL linkage. It's the nut on the far right in the picture with the little linkage to the longer vertical linkage piece.
I accessed it from the top with a speed handle and long extension.
I don't know if you can get to it from beneath.
Old Nov 3, 2010 | 08:24 PM
thehun's Avatar
I can go side to side on mine...but not up and down...its stuck in 4hi..it will lock in 4hi
can my problem be a solenoid issue? if so can I just take the solenoid out?
tsuyoi
Sep 22, 2020 10:37 AM
windriver
Mar 28, 2017 07:31 AM
cornbreadj
Dec 27, 2014 07:50 PM
tomfraser
Dec 7, 2008 03:54 PM
johnkbl
Apr 2, 2007 01:08 PM
