diff lock question
Old Feb 8, 2022 | 12:16 PM
dicksoutforharambe's Avatar
Default diff lock question
hey guys, I've got my transfer case on the bench. Ive been replacing all the seals and o-rings to stop the leaks. it came out of and automatic and it worked fine before I took it out aside from the leaks. With it on the bench I can't seem to shift it from high to low. I left the rover in park before I took it out. So I'm wondering does it have to be in neutral while trying to shift between high and low? thanks
Old Feb 9, 2022 | 10:06 AM
WaltNYC's Avatar
yes it does
https://www.roversnorth.com/parts/bt...shift_defender
Old Feb 9, 2022 | 10:54 AM
Thanks Walt, I didn’t want to get it all back together and then have to do it over.
Old Feb 9, 2022 | 08:03 PM
JohnZo's Avatar
So, when we are driving, of course we should be in neutral and stopped or slow. Slow helps align the gear teeth.
But on the bench the TC will shift easily, so long as the teeth line up. The hi/lo shift mechanism can be viewed under the big cover. You should be able to fidget a bit and shift on the bench, and diff lock too.
windriver
Mar 28, 2017 07:31 AM
instg8r
Jan 7, 2012 03:13 PM
srfnsno99
Aug 28, 2011 10:46 AM
97DISCOIDAHO
Apr 13, 2007 11:09 PM
Acer
Feb 25, 2005 10:29 PM
