Disco 1 oil cooler line replacement question. Anyone use ROX ss braided kit?
Old Apr 1, 2018 | 08:25 PM
cmpeng's Avatar
Default Disco 1 oil cooler line replacement question. Anyone use ROX ss braided kit?
Hello-
I need to replace my 1996 Disco 1 oil cooler lines. After doing a little online research I came across the ROX stainless steel braided lines that East Coast Rovers are advertising Defender owners switch to. I believe ECR and Trailhead 4x4 (In Ohio) sell ROX oil cooler line kits for the Disco 1s but they aren't cheap ~$290.
Has anyone installed these kits on their vehicle- comments?
Has anyone got a DYI solution to oil cooler pipe replacements or are the negative consequences (engine fire) not worth the risk?
My fall-back option is to just order OEM oil cooler lines from a place like AB, Paddock, Bearmach, Lucky8 etc....
Thanks-
cmpeng
Old Apr 2, 2018 | 01:22 AM
OverRover's Avatar
The OE Oil Cooler lines are fine just go to Summit Racing, Jegs, etc and get some High Temp HEAT SLEEVE material.
There are many brands like Thermo-Tec, DEI, Vibrant Performance...just to name a few.
Get some with the highest heat rating, slip it on... and you are back to HAPPY TOWN!
The stuff is inexpensive and works very well to keep the manifold from ever cooking the hoses.
And one Headsup with the OE lines, be sure to check that the Orings are in place and NOT damaged BEFORE you install them.
Old Apr 4, 2018 | 10:05 AM
grenade's Avatar
Find out the thread size and pitch of the fittings and visit your local hydraulic shop. They will be able to build or sell you exactly what will work for oil and transmission temps.
murray97DI
Mar 30, 2016 10:56 AM
Hawkeye712
Aug 31, 2015 03:44 PM
Beaulim
May 2, 2014 08:03 PM
blurover
Nov 29, 2013 01:26 PM
GeorgeD
Mar 13, 2009 07:46 PM
