Disco 1 oil pressure switch
Old Apr 29, 2026 | 05:26 PM
Amber303's Avatar
Default Disco 1 oil pressure switch
Can anyone confirm the location of the oil pressure switch and part number. My car specifically is the 1998 Discovery 1 anniversary edition. It is having some issues with oil pressure when idling and replacing the switch seems like the first step. Part number I am pretty sure is STC4104. Is it located just above the oil filter? Any other advice would be appreciated. I have limited tools and not a great place to work on it so if this is a pretty quick fix hopefully I am able to do it myself.
Old Apr 30, 2026 | 09:58 AM
disco96sd's Avatar
Old May 1, 2026 | 12:14 AM
JohnZo's Avatar
Comes with metal seal washer for flat mating surfaces or a rubber o-ring for the tapered surface. Maybe try heavier weight oil, e.g. 10W-40 or 15W-40, that should raise the oil pressure compared to 5W-30.
gbob
Aug 8, 2021 01:35 PM
jvarnadoe
Jun 17, 2021 09:03 PM
markdeg
Apr 22, 2019 05:33 AM
Matt927
Jul 5, 2016 09:03 AM
tango123
Nov 23, 2009 08:42 PM
