Disco 1 power steering gearbox rebuild kit?
Old May 4, 2011 | 04:29 PM
  #31
ShadowMerchantBC's Avatar
Banned
Need some quick advice regarding final installation of the gearbox. Have it bolted tight to the frame and I have the hoses properly attached. Now I just need to recollect the tire rod end to the control arm. If I'm not mistaken I have to remove the large nut on the arm in order to adjust the arm in the correct position above the tire rod end? As of now the nut is stuck on there tight. Tried using hammer, turbo torch and penetrating oil but still no luck. Been working with a 1 5/16 wrench but part of the handle has broken off so leverage is limited. I had little trouble removing the nut on my original gearbox but this one is stubborn. Any ideas? Also is there any other way to adjust the arm without removing the nut?
Old May 4, 2011 | 04:32 PM
  #32
Banned
Here's the arm in conjunction with the tire rod end.just need to move the arm over a inch or 2. Name:  IMAG0050.jpg
Here's the stubborn nut.
willypilgrim
Oct 19, 2013 08:05 PM
vandal996
Mar 8, 2012 02:17 PM
jycsalas
Apr 17, 2009 02:21 AM
tailchaser0527
Jan 5, 2007 03:52 PM
