Disco 1 stuck in park
Old Jan 31, 2025 | 11:05 AM
tegs's Avatar
4th Gear
Default Disco 1 stuck in park
Hi all,
Ive recently brought a 1998 Disco 1 V8 auto jap import as a project.
We have just got it to start and run now we are trying to get it to move but appears to be stuck in park. We have checked the brake light switch and had a look at a few fuses but no luck.
I have seen a post about someone’s leaky sunroof causing it to seize and this is likely as the sunroof is stuck open.
Any suggestions or anyone who has experience with similar would be greatly appreciated.
Many thanks,
Tegan
Old Jan 31, 2025 | 11:22 AM
jimvw57's Avatar
Sounds like the shift release button is not connected, or the brake solenoid is not working... Hard to tell over the internet without having a hand on the shifter to see what it is working
Old Jan 31, 2025 | 01:47 PM
WaltNYC's Avatar
How did you check the brake light switch?
Try this...
https://landroverforums.com/forum/di...72/#post918222
Old Jan 31, 2025 | 11:37 PM
JohnZo's Avatar
There are interlock circuits between the key, shifter, and brake. There are two brake switches. One with a CC vacuum hose attached, and one with only wires. Maybe download the wiring diagrams from Walt's signature to help troubleshoot. Electrical Troubleshooting Manual (ETM) is very British. Don't know what you mean by jap. Maybe you are on the wrong forum.
Old Feb 2, 2025 | 02:27 AM
tegs's Avatar
4th Gear
Try this...
Thank you for your reply! One of the brake lights is working therefore I’ve been told the switch must be to.
Old Feb 2, 2025 | 02:30 AM
tegs's Avatar
4th Gear
Thank you I will definitely look into this! It’s a Japanese import, Honda had a partnership with land rover and made the Honda crossroad (just a debaged disco 1) and a lot of them were imported back to the uk so it should be the same.
Old Feb 2, 2025 | 02:31 AM
tegs's Avatar
4th Gear
Thank you. Do you know how I would check these?
Old Feb 3, 2025 | 10:20 AM
WaltNYC's Avatar
it may very well be fine, but for the cost of a paperclip you can eliminate that issue with more certainty. Nothing could be easier.
Old Mar 14, 2025 | 09:43 AM
Machinistbutler's Avatar
What's up with the added links to posts that sturgeongenera is adding? Something seems odd.
tannerdc
May 30, 2024 06:27 PM
suzukisam
Mar 27, 2020 06:55 PM
suzukisam
Mar 24, 2020 06:33 PM
handsome rob
May 12, 2017 10:10 AM
pedro_malo
Aug 25, 2014 06:58 PM
