Disco 1 transfer Case removal
Old Jul 17, 2023 | 06:00 AM
Jefro521's Avatar
Default Disco 1 transfer Case removal
Hi lads.
Currently working on removing a transfer case from my Disco 1 300TDi Auto.
Doing this with engine and gearbox still in place and it's a being a bit of a mongrel.
Have the handbrake assemble off and have removed x5 bolts (of varying length) from the housing.
Are there any more securing it as it doesn't seem to want to seperate from the gearbox as yet.
Any tips appreciated
Old Jul 17, 2023 | 11:13 AM
hrhoward's Avatar
Do you have a copy of the workshop manual aka RAVE? Procedure for yanking it is on pages 416-417.
Link for downloading RAVE: RAVE Manual (hat tip to WaltNYC)
Old Jul 17, 2023 | 11:20 AM
robertf's Avatar
v8 auto has a brace from the bellhousing to the right side. dont know if tdi has that
undo shifters and breather line
Old Jul 17, 2023 | 03:18 PM
WaltNYC's Avatar
You'll need to disconnect the lever (shifter) from the xfer case obviously.
This is from a D2 but it shouldn't be much different
Old Jul 18, 2023 | 09:15 AM
DHTaylor's Avatar
Just happen to have a D1 LT230Q sitting in the back yard that I have yet to throw away. Here is the bolt pattern for the transfer case that attaches to the transmission. I show more than 5 bolt holes. But, that does not mean each bolt hole has a bolt in it. I know the bolt for the gear fluid fill hole is one that actually attaches to the transmission. I would check these bolt holes as I show, which you would need to flip it around mentally, and ensure you have them all removed.
june82000
Sep 27, 2015 07:03 PM
cornbreadj
Apr 5, 2015 09:20 PM
Walko327
Apr 1, 2013 05:39 AM
discokauai
Aug 6, 2008 09:48 AM
ajh
Oct 23, 2006 09:42 PM
