A bit lost with transfer case tear off.
Old Mar 28, 2013 | 08:01 PM
Walko327's Avatar
Default A bit lost with transfer case tear off.
Ok 98 disco. taking off transfer case ( see thread : did my transfer case eat itself) how many bolts actually hold the transfer case to the transmission? I've got the mounts undone. And the strap off. But I'm not quite sure what bolts actually remove the case from the trans? It looks like the three on the driver side just above the mount. Is that correct? Still taking one off from junk yard before I completely take mine off so to learn with out screwing mine up. Never done transfer case on anything before. Thanks y'all, workin hard to get rover Rollin again.
Old Mar 28, 2013 | 08:30 PM
Disco28's Avatar
Default Check this link out
This link might be able to help a little. I personally haven't taken one off (yet). It shows the LT230 and you might be able to see the locations of the bolts.
Hope this helps a little.
Old Mar 28, 2013 | 09:26 PM
Walko327's Avatar
That did help! I can confirm the three and maybe a fourth bolt. Can anyone confirm the final count on bolts that secure transfer case?
Old Mar 30, 2013 | 09:26 AM
dansgt's Avatar
I think there's 6, 4 one way and 2 facing the other, but that was a year ago I did mine, so it's hard to remember, I tear apart heavy equipment daily so that clouds my memory of that job a bit.
Old Apr 1, 2013 | 05:39 AM
Walko327's Avatar
Yes the final count is six. 4 aft 2 forward. They are hard to get to in a junk yard with no jacks allowed. Had to remove cross member and let trans and case "hang" to finish off the last 2 bolts. P.s. that thing weighs a ton,especially one man pulling it off on a gravel lot. My back looks like a wild night in the sack.
Pacerlive
Oct 20, 2011 03:09 PM
MrFlea
Sep 4, 2011 11:54 PM
n1keaddict
May 11, 2011 06:46 PM
shonuff93
Feb 20, 2010 10:23 PM
dgilaon4
Jul 7, 2009 08:40 PM
