Disco 1 - Unknown part on front axle
Old May 15, 2022 | 08:51 PM
muzzmobile's Avatar
6th Gear
Default Disco 1 - Unknown part on front axle
Hi all,
The title says it all really, just wanting to know what the part circled in red is?
Looks to me to be for absorbing some kind of vibration or shock, however the way it's attached I'm a bit unsure. Truck is a 94 Disco 1.
Thanks in advanced
Old May 15, 2022 | 11:10 PM
JohnZo's Avatar
Yes it reduces high frequency vibrations. I think the cable is a safety to retain the weight in case the rubber fails.
Old May 19, 2022 | 03:36 PM
roversweed's Avatar
As johnZo said its for N.V.H. Noise/Vibration/Harshness. The cable is a safety catch. Some people remove them and see no additional vibrations, some people say they notice an increase if removed.
Old May 19, 2022 | 07:30 PM
JohnZo's Avatar
It is probably sized to dampen certain gear or u-joint resonant frequencies (ringing) at highway speeds. Probably won't make an impact for typical off-roading. It will work with the drag arm bushings to prevent resonant rotational vibrations of the axle.
Old May 19, 2022 | 08:47 PM
muzzmobile's Avatar
6th Gear
Thanks for all the info.
Basically confirmed what I was thinking. I'll stay there for now as it's not doing any harm.
Cheers
martinezparamounttkd@gmail.com
Dec 28, 2021 04:39 PM
Shiftonthefly1
Nov 13, 2014 11:55 PM
ZGPhoto
Apr 9, 2013 01:52 PM
handsome rob
Sep 17, 2007 11:16 AM
dinandan
Aug 7, 2007 05:08 AM
