Axle Retaining Nut
Old Apr 8, 2013 | 05:08 PM
ZGPhoto's Avatar
Default Axle Retaining Nut
Anyone have the correct size so I can purchase a socket? Installing new Ashcroft HD axle shafts. Thanks.
This guy --> Name:  k4rk32T.jpg
Old Apr 8, 2013 | 05:12 PM
jafir's Avatar
I think Tom Rowe recently said it was 32mm.
https://landroverforums.com/forum/ge...t-58033/page2/
Old Apr 8, 2013 | 05:14 PM
ZGPhoto's Avatar
The antichrist knows all, thank you!
Old Apr 8, 2013 | 08:00 PM
antichrist's Avatar
Hardly. And it's just from memory so don't put money on it.
Old Apr 8, 2013 | 09:24 PM
ZGPhoto's Avatar
I already put money on it haha...ordered from Amazon...
Old Apr 9, 2013 | 12:37 PM
Better plan on finding one hell of a big/strong torques wrench, that bolt torques to 350 foot pounds.
Old Apr 9, 2013 | 01:01 PM
ZGPhoto's Avatar
Where are you seeing that? I can't find anything of the sort in rave.
Old Apr 9, 2013 | 01:52 PM
04duxlr's Avatar
It's there, but Mike was a little low. A 3/4 inch torque wrench will give you that, or you can always use math. Get a breaker bar and a pipe, tighten the nut as much as you can then set it up so that the handle is just about horizontal. Make a mark on the pipe that corresponds to where you would need to stand to make the same amount of torque and then stand on it. 360 ft. lbs. of torque is 360 lbs. at 1 ft. from the center of the nut. If you weigh 180 lbs., stand at 2 ft. from the center of the nut and you have the same torque.
Or you can put an impact gun on it and lay into it. You are just clamping the hub between the axle stub and the flange so it's not like you are setting a preload on a bearing. Too loose will end badly, though.
File Type: pdf
malmberg
Sep 24, 2020 05:06 PM
LADEROUTE
Feb 11, 2015 07:52 PM
bagocheetohs
Feb 21, 2014 11:29 PM
Rock Sing
Jun 21, 2013 07:21 PM
cationmoted
Oct 19, 2012 07:39 AM
