Disco 1 won't move in gear
I hope not, either, or it's going to be a quick trip to Craigslist for this royal brick.
Rob
High is straight up vertical, Neutral is one notch towards rear at 45 degrees and Low is one more notch to rear and now horizontal.
Yes and the dog ear that the rod attaches to on the tc is what I was referring to. It should move easily as it rotates. If it hasn't been worked in awhile it might be stiff. If the dog ear isn't vertical it's in neutral...... one notch forward (High) or rearward (Low) will engage it. You'll get a positive "click" when it's engaged (detent ball and spring) in any of the three positions. If not it needs to be worked back and forth with a few drops of 10W or thin oil.
I had a chance to monkey around with the truck today, and I wanted to pass on what I've found.
Never being one to stand on niceties, and since I have big mitts (and am I'm tired of scraping my knuckles off on this @#&%!! truck), I decided to pull the carpet and insulation back, and cut a rectangular hole in the tunnel for ease....I'll cover it with a panel and some screws later, and call it an "user-defined access panel", lol.
Having done so, here's what I see:
It looks okay, but here's deal: It won't move. To any position. Period. As you can see, I've disconnected the linkage by removing the clip and pin, but no matter what I do (i.e., pry bar, hammer, channel locks, Vice Grips, etc.), the lever will not budge. No detent and ball action whatsoever, like it's frozen or jammed, and even oil won't loosen it.
I also thought that maybe the trans should be in Neutral for it to move, but no dice with that, either.
Any ideas of why it's not shifting, and if this could be part of the problem?
Rob
Rob
