Disco 1 won't move in gear
Old Jan 12, 2014 | 03:30 PM
  #21
TOM R's Avatar
Engine running with trans in neutral?
Old Jan 13, 2014 | 08:50 AM
  #22
Ghostsoldier's Avatar
Negative, Tom...the truck was not running; I only unlocked the column and put the trans shifter in neutral. Should I try it running?
Rob
Old Jan 13, 2014 | 09:50 AM
  #23
fishEH's Avatar
I'd try it in as many different ways as possible. Running in neutral and in gear, not running in gear and in neutral, try rocking the truck back and forth while trying to move the lever.... Could be something is just jammed and needs to be popped loose.
Old Jan 13, 2014 | 10:07 AM
  #24
Matt_Attack352's Avatar
Did you ever get around to checking the fluid level in the transfer case? Just a few days ago my rig decided it didnt wanna drive and low and behold my tcase had decided to run damn near dry. I pulled the drain plug and inspection plate to make sure it wasnt burned up. Resealed, refilled. Drives like a champ again.
Old Jan 13, 2014 | 10:47 AM
  #25
I'll give that a shot, fish...I even considered using a padded wrench to jiggle/turn the TC/front differential driveshaft.
Negative, Matt, as I was dodging thunderstorms all weekend, but I'll definitely give it a check.
Rob
Old Jan 20, 2014 | 04:29 PM
  #26
Here's an update...I pulled the fill and drain plug on the TC, and only about 3 tablespoons of gear oil came out. I checked it for metal, and it seems to be okay, but there's absolutely NO oil in that case.
I'm assuming that might be the problem....at any rate, I need to refill it, so it's off to the auto parts store for some gear oil and a pump.
I'll let you know what happens.
Rob
Old Jan 20, 2014 | 04:37 PM
  #27
TOM R's Avatar
Last guy with same problem also ran the case dry, he got lucky removed the inspection cover gears were ok , added oil and still works
I would pull that cover and look at the gears before wasting good oil
Use "the right stuff" rtv for the gasket after spraying it clean with brake spray
Old Jan 20, 2014 | 05:24 PM
  #28
As TOM said, me being the last guy, hope you're gears aren't fried. I got lucky that it decided to not want toove while I was in front of my house. Just get some RTV and brake cleaner. Clean the surfaces and stuff. Easy cheesy. Buy a gallon jug of gear oil and a hand pump. Most auto parts stores have them. If autozone has it, a decent store will too. Good luck!
Old Jan 20, 2014 | 06:13 PM
  #29
Guys,
I just got back and put two quarts of gear lube in it, before I saw your posts....should it take a gallon of oil to fill it? It sure seems like 2 quarts aren't enough, although I picked that number up on another post here somewhere....
Also, because I didn't check-in until now, I also didn't pull the cover to check for damage; before I add more oil, would it be wise to do that first?
And if so, and I find any metal bits, will the transfer case be effectively D.O.A.?
Rob
Old Jan 20, 2014 | 07:16 PM
  #30
TOM R's Avatar
Look for chipped tooth, blue discoloring , teeth pointed on ends, cupping of teeth
If you drained it and got no metal don't think you will find any in the case unless it is sludged up inside
Think I would try it out since you already added the oil
