Disco '97 electrics
Old Aug 16, 2012 | 12:39 PM
No, it is still an easy repair. First be sure that problem is no spark. When this happens, take a spare spark plug, and connect to plug wire and lay on the manifold. Crank and check for sparks. Ignition amplifier is part of distributor, sort of plastered on. There is a relocation kit that extends the life of it. But this time it might just be a trashy connection.
Amplifier Module Relocation Kit (Part # STC1856) - Land Rover ignition from Atlantic British
and the module
Land Rover Ingnition Amplifier Module (Same Fit As Genuine Part # STC1184) | Land Rover Engine Parts
Now for future, consider yours a 1995 for most purposes, and use that section of the RAVE shop manual set.
No bonfires except as celebration once work is done to praise and honor the Rover gods, with meat roasting, cool beverages with more alcohol content than American gasoline, and scantily clad women who love men, mud, and the machines they cherish. Might be slightly illegal in your neigborhood, adjust the alcohol and amount of female exposed skin to local requirements.
Old Aug 16, 2012 | 03:47 PM
Danny Lee 97 Disco's Avatar
Is the engine designation a 3.9 or a 4.0 just out of curosity.
You also would not have the same emissions equipment that the US version would have is my guess.
Is it fuel injection or carb?
Old Aug 17, 2012 | 07:31 AM
MIDEASTSTEYN's Avatar
4wd High
3.9 fuel injection
Old Aug 17, 2012 | 07:43 AM
4wd High
Cheers Sanannah Buzz. I'll give it a bash. I see that i have the relocation kit installed. I'll check all the connections on it first. I also have two small condensors fitted to the coil? Any idea? Radio suppresion perhaps?
Old Aug 17, 2012 | 08:22 AM
Condensers help reduce AM radio interference, and in old days before electronic ignition helped reduce erosion of the "points" or contacts that drove the spark coil. Some iginition systems (like certain Mercedes) have an extra shield layer around the plug wires to knock it down even more.
Old Aug 17, 2012 | 08:32 AM
4wd High
Will the ultragauge OBD2 code reader work on my vehicle?
http://www.ultra-gauge.com/ultragauge/index.htm
Old Aug 17, 2012 | 09:34 AM
Nope - needs to be GEMS or Bosch fuel injection ECU. But you can hook up your own heat and oil PSI gauges, etc. If tempted to test, try an auto parts store and see if their code reader will read it, if so the Ultra Gauge will work. Dealers had a computer that would read earlier models.
Old Aug 17, 2012 | 09:43 AM
4wd High
Gr8. Thanks for the info.
muscarello
Feb 19, 2015 12:57 PM
rwarren92
Engine & Internal
Apr 28, 2008 09:15 PM
gsgtsg
Feb 28, 2008 06:36 PM
alanroberts50
Nov 21, 2007 08:48 PM
edbar
Jan 1, 2005 09:08 AM
